telling the difference
Old Apr 22, 2010 | 02:02 PM
mk2 escortcos's Avatar
mk2 escortcos
Default telling the difference
how do i tell the difference between a 2wd head and a 4x4 head any notable stamps numbers etc.
Old Apr 22, 2010 | 03:40 PM
Alvyn's Avatar
Alvyn
as you look at the head from the front on the left hand side at the top there'll be 2 lugs sticking out on the 2 w/d head whereas the 4x4 hasn't!
Old Apr 22, 2010 | 03:55 PM
Dezzer's Avatar
Dezzer
4x4 resto
The lugs as mentioned above ,the temp sender for the gauge is located near the coolent temp sensor at the back of the head on a 4x4 ,the oil feed for the turbo is on the head in the middle of the exhaust side on a 4x4.
Old Apr 23, 2010 | 12:57 PM
Ther eis also a early and a late 2wd head, the early one has much smaller washers under the head bolts, sapphy's(2wd) are bigger so spread the load more.
Old Apr 24, 2010 | 01:43 PM
mk2 escortcos
cheers for that.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
