ford focus engine mangement light
Old Apr 16, 2010 | 10:23 PM
alexwhitefoot's Avatar
alexwhitefoot
Question ford focus engine mangement light
hi guys
i have a ford focus 2001 the engine management light is on dash i have had it turned off and reset and the lambert sensor changed i just wanna turn it off myself without spending money help
Old Apr 17, 2010 | 06:58 AM
oldford's Avatar
oldford
You can either try disconnecting the battery for a couple of minutes or buy a scanner that will do it for you.
But if the light is on, there's usually an error and the light will be back on after clearing it very quickly.
If the light is on because of the problems with the Oxygen sensor (Lambda sensor) then it should go out in 2 or 3 days because you have a new sensor now.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
taylora1409
Aug 12, 2015 12:06 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
Old ford
Jul 31, 2015 06:50 AM
