Oil filter Thread size,
Old Apr 12, 2010 | 09:35 PM
16EBoy's Avatar
16EBoy
Default Oil filter Thread size,
Hi Boys and Gals,
Quick question for you
Whats the thread size for the oil filters on the cossie blocks, ? also the depth and width of the filter.
i believe the thread is, 3/4 x 16 thread.
Thanks in advance.
Old Apr 13, 2010 | 01:31 AM
jon@work's Avatar
jon@work
The thread is indeed 3/4
The filter sizes are different depending on if the car is 2wd or 4x4. This is down to the different engine crossmembers and engine mounts, and lack of clearance between the filter and 4x4 engine mount. The 4x4 oil filter mounts remotely on an arm to the rear of the engine mount, whereas the 2wd filter bolts straight on to the block with the modine (water-oil cooler) sandwiched in between.
s1cab
Jul 26, 2018 06:11 PM
cossirob
Aug 29, 2015 03:23 PM
mrmann
Aug 20, 2015 11:24 PM
muffster
Aug 17, 2015 08:17 PM
Roosie
Aug 9, 2015 07:37 AM
