cosworth running problems
Old Apr 9, 2010 | 09:19 PM
fostersice's Avatar
fostersice
Default cosworth running problems
fitted a cosworth engine into a mk2 escort
i have fitted a 4wd engine using a 2wd sump
rainbird plenum
megasonic dump valve
3bar map sensor
rs500 intercooler
standard ecu
problem i have is
i get everything wired up and tryed to start it today
after playing with the ht leads and getting to run its seems to be ticking over very fast 3000revs
am i missing something do i need a animal valve????
the guy doing the wiring thinks the ecu could be at felt???
please help after 10months of building the car and finding a brand new cosworth engine from tickford ford
i cant believe im still having problems
Old Apr 9, 2010 | 09:22 PM
rscos2004's Avatar
rscos2004
Default cosworth running problems.
rainbird plenum
3bar map sensor
rs500 intercooler
standard ecu
problem i have is
Ive had this with my last one and it was an idle control valve hope this helps as im having a headache with my latest one cheers.
Old Apr 9, 2010 | 09:26 PM
fostersice's Avatar
fostersice
is that the red thing on the throttle body????
Old Apr 9, 2010 | 09:32 PM
COLEYST200's Avatar
COLEYST200
no mate wot he means is the uver thing on the throttle bodie that sticks out and has a plug on it
Old Apr 9, 2010 | 09:35 PM
COLEYST200's Avatar
COLEYST200
or you need to ajust the throttle bodie it self as there are 2 settings on it 1 is the air and the uver dose the butter fly inside the throttle bodie
Old Apr 9, 2010 | 09:38 PM
botters's Avatar
botters
competant bodger
disconnect the idle speed valve and see if the revs drop its the stubby tubular thing on the throttle body just disconnect the plug while its running
Old Apr 9, 2010 | 09:43 PM
COLEYST200's Avatar
COLEYST200
the red thing is the ( throttle position sensor ) and you will have set that up as well mate you have to use a volt meter to set it up
Old Apr 9, 2010 | 10:11 PM
fostersice's Avatar
fostersice
i pulled the plug off the idle valve when it was running to nothing changed
we tried playing with tps and nothing the tec guy thinks its no good then again
he has told me the ecu is no good aswell ?????
Old Apr 9, 2010 | 10:12 PM
fostersice's Avatar
fostersice
free sunday dinner to anyone who can sort it for me lol
and as much tea/coffee you can drink
Old Apr 9, 2010 | 10:17 PM
botters's Avatar
botters
competant bodger
ecu is possible but unlikely have a spray around the inlet manifold with brake cleaner or something similar and see if the revs pick up if they do it could be an air leak only need a small leak to raise revs a lot while not under load
Old Apr 9, 2010 | 10:28 PM
COLEYST200's Avatar
COLEYST200
i can not see it being the ECU mate it getting to much air take the pipe off the throttel body and have a look and see if the butter flyis closed if it is then start the motor and see wot the revs are doing if its still to hi put your hand over the throttel and slow the air down and see wot happons if its still running you have a very big air leak
Old Apr 9, 2010 | 10:30 PM
COLEYST200's Avatar
COLEYST200
have you got a up to date photo of the motor ther might be some thing you have mist
Old Apr 9, 2010 | 10:34 PM
fostersice's Avatar
fostersice
botters
you may be onto something when playing the the dizzy to get the car to run im sure i could feel air from the lower part of the plenum
if this is from a bad seal could this make the car rev so high?????
im getting a ecu tomorrow with a 300 bhp chip
if you think it could be the plenum i will have to strip it back down and try and reseal
i used a new gasket and sealant when i did it the first time but im sure i could feel air
Old Apr 9, 2010 | 10:36 PM
fostersice's Avatar
fostersice
Old Apr 9, 2010 | 10:39 PM
Danny @ Enhanced Performance's Avatar
check youve got an idle screw in the tb,as above spray wd 40 around the inlet plenum when running and if the revs dip then youve found a air leak,it wont be tps i doubt but you can also unplug this and still run at idle...
What chip you running ecu etc???
cheers danny
Old Apr 9, 2010 | 10:44 PM
just see pics above(lovely looking motor mate)and see you have idle screw in
Why is the tb upside down???is it std tb??im always sceptical about those blow of valves as iv seen these cause tick over probs but doubt it,do the leak test mate could even of ripped the inlet gasket plenum to head???
cheers danny
fostersice's Avatar
fostersice
buying a ecu from IAN RS2K its a L1 with a Ahmed 300bhp chip
Old Apr 9, 2010 | 10:48 PM
make sure your on a pf01 tps then mate or youl start chasin g your arse..
cheers danny
Old Apr 9, 2010 | 10:49 PM
COLEYST200's Avatar
COLEYST200
this is not about the problem your having with the motor running but one thing i have sore is the size of the pipe you are running on the pumps are they big anuth to do the job wot size is the i/d of the fittings coming of the tank
Old Apr 9, 2010 | 10:50 PM
fostersice's Avatar
fostersice
thanks mate
im getting the ecu tomorrow night and i have a spare brand new inlet gasket
so sunday ill strip it down again lol and try new inlet seal and try and find a way to get a better seal on the plenum
the engine was brand new for tickford ford and had been bench tested before me getting it so i know the engine is good buy ive had the inlet of and fitted the rainbird plenum since
god i hope this sorts it
taken me 10months so far to build the car from a rusty shell and had it booked in for a mot next week :-(
Old Apr 9, 2010 | 10:52 PM
fostersice's Avatar
fostersice
fuel lines are braided ptfe teflon dash -6 all the way though
Old Apr 9, 2010 | 10:53 PM
COLEYST200's Avatar
COLEYST200
all very good but wot setup is the chip for and wot have you got on your car......injectors
KW235's Avatar
KW235
Standart ECU and 3bar Map?? I´t doesn´t work.
thanks mate
dont worry mate it wont be anything serious,if you ever need any advice just pm me..
as coley just said though check your fuel line sizes..
cheers danny
fostersice's Avatar
fostersice
cheers danny
the tps is the standard one from a 4wd 1995 green top engine
is there a code somewhere on there to say if its a pf01
Old Apr 9, 2010 | 10:56 PM
fostersice's Avatar
fostersice
i tryed it with the standard map sensor no difference
thats why im getting the other ecu tomorrow night
botters's Avatar
botters
competant bodger
botters
could well be the problem mate give all the sealing surfaces a good clean with light sandpaper and fit new gaskets, i wouldnt use silicone sealer as some gaskets dont like it i would use hylomar blue if you can get some its the dogs danglies for sealing anything
Old Apr 9, 2010 | 10:57 PM
depends what map its got if its 3 bar itl be fine but just noticed hes running std blues so why be on 3 bar???
Needs to have the right map etc to run right!!
cheers danny
Old Apr 9, 2010 | 10:58 PM
fostersice's Avatar
fostersice
blue ones ????
KW235's Avatar
KW235
And with the L1 ECU you need a 2wd TPS.
Old Apr 9, 2010 | 10:59 PM
COLEYST200's Avatar
COLEYST200
4x4 TPS are black 2wd are RED and when you go from RED to BLACK you have to swop the 2 out side wires
Old Apr 9, 2010 | 11:00 PM
that will be a pf09 then mate and will be wrong for a l1 ecu ,you can switch the outside wires around that goes to the tps plug but realy you want to run a l8 ecu and make sure the tps wires are configured...it will say on the outside of the tps case what one it is..
cheers danny
Old Apr 9, 2010 | 11:01 PM
fostersice's Avatar
fostersice
should i try resealing everything
replace the 3bar with the standard one untill i know what the new ecu should have??? ie what colour inj?
Old Apr 9, 2010 | 11:02 PM
not always,all the ones you buy now are black but oe factory were red...
cheers danny
Old Apr 9, 2010 | 11:05 PM
firstly what engine loom you running??ie 2wd or 4x4 etc then go std injectors std map sensor pf 09 or 01 and suitable chip and ecu then atleast theres no mismatch...
As said just ask if you get stuck mate..
cheers danny
botters's Avatar
botters
competant bodger
yes mate does still sound like an air leak to me let me know how you get on
fostersice's Avatar
fostersice
cheers danny
yes it has pf09 on it and i know the tec changed the outer wire's around
Old Apr 9, 2010 | 11:06 PM
COLEYST200's Avatar
COLEYST200
At the end of the day the car will run on just about any set up but very ruth wot you have is to much air getting in .its the throttel body setup / air leak im 100% shower
Old Apr 9, 2010 | 11:08 PM
fostersice's Avatar
fostersice
its a 4wd engine but 2wd loom
tps has pf09 on it
botters's Avatar
botters
competant bodger
At the end of the daythe car will run on just about any set up but very ruth wot you have is to much air getting it .its the throttel body setup / air leak im 100% shower
+1
