compression strut kit installation advice
Old Apr 8, 2010 | 07:47 AM
florent78's Avatar
florent78
Default compression strut kit installation advice
I do a search and find several posts on them, but nothing to indicate how to mount them
in fact when you fit the compression strut kit, near the TCA you have a bolt to do the link
and depending how you fit them, it can be "in line" or you can have an angle
see the picture :
I suppose you need to adjust them with wheels on the floor, but after that , you do a 45° angle or you try to do a "straight line" ?
thanks for the advice
Old Apr 8, 2010 | 09:04 AM
JonathanJ's Avatar
JonathanJ
When I fitted these years ago the way I did it was bolt it all together looseley ,the TCA end with the hole in will only really be an easy fit at one point , as soon as you fit the first one it will be clear where that point is . You also have to find the "sweet spot " where as the suspension is in full droop the twisting action of the bottom arm will turn the compression strut and then adjust the spherical joint so it is just clearing the top hat bushes at the chassis mount , it does not take long , just a little bit of patience , then you have to set the castor and repeat the process untill the caster is set and the joint is still clear , there is several ways you can short cut the process to set the castor to a "ballpark" setting , like locking the wheels in the straight ahead position lifting car up on 4 axle stand , remove caliper and use the caliper bolt holes as your datum , take a reading of this and once you have put the compression struts on adjust until this datum figure is reached , I always balance the 2 sides so at least they are the same .
Hope my rambling made sense .
Old Apr 8, 2010 | 09:08 AM
florent78's Avatar
florent78
thanks
perhaps do you have a picture af the TCA/ compression strut
fitted ?
Old Apr 9, 2010 | 07:56 AM
florent78's Avatar
florent78
no picture ??
can be good to see a "good" mount for the compression strut
Old Apr 9, 2010 | 08:10 AM
JonathanJ's Avatar
JonathanJ
Still looking
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
dombanks
Sep 21, 2015 08:38 PM
