1.6 cvh sump
Old Apr 7, 2010 | 02:31 PM
Bob F's Avatar
Bob F
Default 1.6 cvh sump
Hi I have a 1984 1.6 cvh engine and need a new sump does anyone know if the later sumps (1985 on) will fit, mine has the old style gasket (more than one part) there are plenty of sumps on Ebay but all say they are for the later engines that use the rubber gasket, is ther any differance?
Old Apr 7, 2010 | 02:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've never found a diffrerence, best to use rubber gasket and a little sealant anyways.
what engine is this on? as rst's are different to none turbo models IIRC, but only internally.
Old Apr 7, 2010 | 07:28 PM
Bob F's Avatar
Bob F
Thanks the car is a Orion 1.6i
what type of sealent should I use on the rubber gasket?
Old Apr 8, 2010 | 05:22 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i just use a small amount of rtv sealant and i can't emphasise small enough as any excess will eventually fall away and find its way into the pickup pipe and clog it eventually.
Old Apr 9, 2010 | 12:36 PM
Bob F's Avatar
Bob F
Thanks again xr2wishy, just read up on that RTV sealant and they say you only have about 5 mins before it goes off, as I will proberbly be pratting around for ages thought I might use Red Hermetite which I used on the core plugs to good affect or am barking up the wrong tree yet again!!
mk3ste
Oct 17, 2021 10:09 AM
Iain Mac
Sep 30, 2015 09:39 PM
mondeomark
Sep 28, 2015 06:28 AM
youngben
Sep 27, 2015 09:37 PM
