2wd Cossie Missfire
Old Mar 16, 2004 | 06:02 PM
Default 2wd Cossie Missfire
HELP !!! ive got a standard 2wd sapphire cosworth that has devloped an increasingly annoying missfire. It only happens from about 4500rpm upwards. Ive changed the following: - Plugs twice(including setting plug gaps), dizzy cap, rotar arm, phase sensor, leads, ign amplifier, crank sensor, tried a different ECU, coil and amel valve but i still have the problem. When it misses its the very first plug that blacks up (nearest cambelt) Does the phase snsor and crank sensor have a certain gap and if so what is it and how do you adjust it ? Ive even looked at the wiring on the injectors to see if its corroded / broken but all seems fine. Someone please help, itsreally begining to get on my tits !!!!
PS i found this site through the RS Owners club and from what ive seen so far it looks really good![/b]
Old Mar 16, 2004 | 06:51 PM
Dave McB's Avatar
Dave McB
try gettin new plug leads
some of the guys on ere swear that the std plug leads r the best and that other 1s can cause misfires etc
Old Mar 16, 2004 | 08:16 PM
Guinnless's Avatar
Guinnless
Check the lugs on the crank pulley are not damaged and the gap is between 0.6 and 1.0mm.
Phase sensor is 0.2-0.3mm.
What leads and what plugs are you using?
Old Mar 17, 2004 | 08:23 AM
If its number1 only getting sutted up,
u may have a leaking injector.
Old Mar 17, 2004 | 11:51 AM
HI,
Second that martymcfly, swop injector with one of the others and
see if that plug on the swopped cylinder blacks up.if no change
check current to no1 injector,and wiring, plus compression test,
as guinnless above has covered crankpully lug's and phase sensor,
clean up plug before test.
Dave.
Old Mar 17, 2004 | 04:04 PM
Fantasic ill do all that but i didnt think that the crank sensor was adjustable as its on two 8mm bolts init ?
Is it better to adjust crank and phase sensor to the smaller or larger limit measurements ?
Old Mar 17, 2004 | 04:12 PM
HI,
TDC and PHASE sensor, as log as they are in the range of adjustment,
0.6 to 1mm,tdc sensor and 0.2/0.3, phase sensor,
Dave.
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
