CVH backing off...
Old Mar 15, 2010 | 08:14 AM
Silver'Scort's Avatar
Silver'Scort
Default CVH backing off...
Hi all, got a weird fault with my '90 carb fed CVH Escort 1.6 sport.
Every so often when under load, usually in 3rd/4rd gear, clog right down, it will begin to back of and bog itself down as if it is being starved of fuel. Usually by dipping the clutch and revving the engine, or sometimes dropping to a lower gear it will clear itself and carry one, however if you keep the foot in, it ill bog itself further and further down until its kangaroo-ing!
The ignition side can be ruled out i would imagine, as its not a regular fault, just as and when, but its had new coil, leads, plugs, diz cap and rotor arm as i had them given with the car so thought i may as well fit them and see if it helps. Only parts that weren't replaced were the ignition amplifier (cant remember if that comes off the dizzy seperate tho with out looking) and the dizzy itself.
If anyone has a suggestion before i start going through the fuel side one bit at a time, it would be great
Old Mar 15, 2010 | 11:43 AM
Your car will have most likely a 28/32 TLDM, same as used on the later XR2, not a bad carb certainly clean no good power wise but there you go.
Anyway clean out the float chamber, take the float out and blow through with an air line after taking the needle valve out that the float closes, you may even find the float is punctured if plastic, if so dry out then seal hole with glue.
It defo sounds like crap restricting the fuel flow, the normal problem on these when people always drive really gently is the secondary venturi seizes up, this is vacuum operated and they seize through lack of use, could also pull the pipe that feeds the vac unit and suck on it to make sure it holds pressure/vacuum.
Old Mar 15, 2010 | 10:51 PM
Silver'Scort
Ok Tabetha, thanks for that advice, a good mate is lending me a good TLDM weber for me to put on while i take mine off and strip it down to clean it.
Never stripped down a Weber style carb before, done plenty of Motorbike carbs, but it'll be a learning curve
Old Mar 16, 2010 | 05:12 PM
They're very easy, if you remove the secondary venturi vacuum diaphragm top and cut 1 coil off the spring, the secondary venturi will open sooner, make it a bit livelier!!
Old Mar 16, 2010 | 09:07 PM
Silver'Scort
Haha cool, so the vacuum diaphragm, am i right in assuming that is the flying saucer type thing on the top of the carb under the airfilter?
Old Mar 17, 2010 | 02:52 PM
Yes, it will have a small pipe going to the venturi side and a rod out the bottom that attaches to the secondary venturi linkage to operate it.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
s1turboman
Aug 29, 2015 04:27 PM
bigryrs
Aug 29, 2015 10:51 AM
Ben26
Aug 27, 2015 08:56 PM
