engin not starting
Old Mar 11, 2010 | 11:58 PM
fixerdude1's Avatar
fixerdude1
Question engin not starting
How do i check the compression of the engine if it wont start, as the manual says that i have to run the engine for a while also if the problem lies there then what do i need to do to fix the problem
Old Mar 12, 2010 | 07:22 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
does it turn over and have you got a compression tester
Old Mar 13, 2010 | 10:58 AM
Don't need to run engine at all to do a comp check, so long as turns over on the starter, take plugs out, put gauge in spin engine take reading.
Old Mar 13, 2010 | 05:04 PM
fixerdude1's Avatar
fixerdude1
there is little to no compression, am about to strip engine to find out the cause, where to start is the question
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 20, 2015 09:21 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
