which aftermarket ecu to use in 3door
I need some help and advice on which ecu to use in a 3 door sierra cosworth. i understand there are quite a few aftermarket ones out there at the moment but im unsure which one will benifit me. i would ideally like around the 500 bhp mark.
thanks kyle
thanks kyle
Sponsor
kyle ive probably had more ecu's on a cossie then anyone else on this forum i wanted to learn how to map so going through to get a better picture ! now if you want just 500 bhp a webber l8 will do fine tuned ny turbo systems or msd nms reyland scs if you have the engine ect to cope .Now if you want all the trimmings I.E launch antilag flat shift ect ect ect ect the ma developments do a vipec which works brilliantly or go pectel t6 which is probably the best ecu out there for a true working in every way ecu
so to cut short think what you want from the car barring power
I recomend you find a mapper you are happy with and ask them what they prefer and why.
Mark
DixieTheKid
14-09-2015 09:04 PM
