fan heater motor
Old Mar 9, 2010 | 02:41 PM
andyhib7's Avatar
andyhib7
Default fan heater motor
Hi Could anyone give me a bit of advice on my sierra xr4x4 2.0L dohc .The fan heater motor seems to have given up, it has power to the fuse and it also has air-con.Does the task involve disconecting air-con pipes which i know at present are empty to gain access and what else does it involve
Many thanks cheers Andy.
Old Mar 9, 2010 | 03:30 PM
Only ever worked on one air con sierra, under the scuttle panel you will see the heater motor as the forward most part, of the casing that surround the evaporator, where it goes through the bulkhead.
I can't remember whether the fan is accessible or not, just lift the panel in the centre covering it.
I'm inclined to think it is a whole unit out job, but there may well be enough slack to move it forward enough to enable the fan to be changed in situ without disconencting the air con pipes.
Prior to the above though I would check the wires at the fan are actually getting a good earth and the switched varying voltage lives, as it could just be the earth wire broken or the switch duff, so could always check power here first.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
bobsworth
77
Mar 24, 2016 09:30 PM
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
