MAP Sensor problem
Old Mar 8, 2010 | 01:58 PM
kebkiss84's Avatar
kebkiss84
Default MAP Sensor problem
hello,
I have a ford fiesta 1.4 16v zetec 53 plate and according to a diagnostics the MAP sensor needs replacing, is this a difficult job? how much is it for part? does anyone have a picture of where it is located?
Thank you
Old Mar 9, 2010 | 07:14 AM
martysmartie's Avatar
martysmartie
Certainly will be a MAF not a MAP, it is located in front of throttle body basically a wire mesh which a current is applied to "Hotwire" the advantage being air temp can be measured as well as density. Can't help on price but would suspect it to be around £20 from Ford maybe more. Not difficult to do.
Martin
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
