power loss from transmision
Old Mar 7, 2010 | 07:59 AM
cuprabob's Avatar
cuprabob
Default power loss from transmision
Hi any one know how much power or percentage can be lost from the engine power on a cossie 4x4 basicaly if the cars running 300 or 350 bhp at the wheels what power should be at the flywheel any can anyone check there rolling road reports and let me know what sort of difference there is thanks.
Old Mar 7, 2010 | 08:24 AM
oldford's Avatar
oldford
It's has been a while, but I know we measured 90 - 92 bhp of loss on an Escort Cosworth with 300 bhp at the flywheel. Maybe this rolling road exaggerated a bit, but the minimum loss would something like 70 bhp.
Old Mar 7, 2010 | 10:01 AM
cuprabob's Avatar
cuprabob
thanks for that anyone else got any ideas also check your rr print outs if you could cheers
Old Mar 7, 2010 | 10:24 AM
m4tt274's Avatar
m4tt274
isnt it meant to be 25%
i was producing 229bhp at wheel and the operator said about 300 @ fly
Old Mar 7, 2010 | 10:31 AM
cuprabob's Avatar
cuprabob
i think you may be right i read some where 2wd cars can be about 15-18% and most not all 4wd cars are about 20-25% i just wanted to see what other people's results were any more takers cheers
Old Mar 7, 2010 | 01:18 PM
I know mine was 259@wheels, 297 crank, on low boost, but it's 2wd, I'd expect 4wd to be between 25 to 30%, some are nearer 35 though.
Simple way to find out is get it on the rollers that can actualy measure precisely the trans loss in coast down test, you'll have exact firgures of wheels and flywheel then.
Old Mar 7, 2010 | 05:14 PM
oldford's Avatar
oldford
It is my believe that the transmission loss is a fixed number of bhp, not a percentage.
I have tuned a lot of cars and usually had them on a rolling road before and after. The transmission loss was always almost the same (plus or minus 1 bhp).
Lets say I have a car with standard 300 bhp and 4-wheel drive. Put it on a rolling road and measure 200 bhp on the wheels and 100 bhp losses. Then I tune the engine to 600 bhp (supercharger, No2 injection, you name it) with same rev range as standard and measure it again. If the loss is 33%, I would now have 200 bhp loss. But the transmission has not changed. So, I would still measure the same 100 bhp loss.
Old Mar 7, 2010 | 05:40 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
http://www.pumaracing.co.uk/POWER3.htm
give this a read......ps my last R/R was 427 fly and 360 wheels.......so that's less than 20% on a 4x4
Old Mar 7, 2010 | 08:10 PM
Read it, it's very presumptuous on thier part to assume wheels spin on all rollers, some like the one I use regularly re grip the rollers, and calibrate it often, by measuring run down losses flywheel bhp comes about, as well as crank, the difference between the two is the trans loss.
Some rollers can't be beleived anyway, as the trans losses are sent to them on a compy link or data link, that's why they are easy to fiddle.
The ones I use also have a engine dyno, and the rollers read within 1bhp of the engine dyno, so good enough for me.
Trans losses also increase with speed, pumping up tyres on a decent dyno gives no more power as trans loss, ie costa down puts it back to square one accuracy.
Old Mar 7, 2010 | 08:14 PM
botters's Avatar
botters
competant bodger
not sure how much loss you get but my 4x4 is stage 3 and is 311bhp at the wheels so im guessing around 50-60 bhp loss does this sound about right?
Old Mar 7, 2010 | 08:20 PM
m4tt274's Avatar
m4tt274
would that stand to reason that an 85bhp pinto wouldnt move with 4x4 running gear?? come on.
Old Mar 7, 2010 | 08:23 PM
botters's Avatar
botters
competant bodger
i think he is giving an example of how transmission losses would be the same at low power and high power not quoting exact figures mate
Old Mar 7, 2010 | 09:51 PM
m4tt274's Avatar
m4tt274
its ok, im not stupid :L
Old Mar 7, 2010 | 10:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
totally, it is a percentage really.
think about it, the harder something accelerates the more resistance in a given time is occurring.
Old Mar 8, 2010 | 07:51 AM
oldford's Avatar
oldford
Loss on a rolling road is calculated when coasting down in neutral. Has got nothing to do with acceleration, but everything with deceleration with ZERO power applied.
Also a different gearbox has a different loss. If the engine doesn't have much horsepower, you need a gearbox with little loss.
And the lower the road speed, the lower the loss. So a 85 bhp car can move a 4x4 car, but just not as fast as a more powerful engine.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
dojj
Sep 29, 2015 10:32 PM
