obd socket on a mk3 mondeo where is it?
Old Mar 6, 2010 | 06:55 PM
base190380's Avatar
base190380
Default obd socket on a mk3 mondeo where is it?
as above 2002 mk3 ford mondeo deisel tddi. i know deisels didnt have to have it but if it did where is it located so i can look for it, thanks paul
Old Mar 6, 2010 | 07:15 PM
Delta-Force's Avatar
Delta-Force
its up behind the dash mate on the drivers side put your hand up the back of the dash and it slides down on a slider you will see what i mean
Old Mar 6, 2010 | 07:18 PM
Delta-Force
Old Mar 6, 2010 | 07:41 PM
base190380's Avatar
base190380
on a slider?? ok will have a look tomorow and see wot i can c
Old Mar 6, 2010 | 08:24 PM
Any car the age of yours has to have it diesel or not, must at that age be OBD2 compliant.
Old Mar 7, 2010 | 07:13 AM
oldford's Avatar
oldford
OBD2 is a exhaust emission rule used in the United States of America and Canada. It has no meaning in Europe and does not apply.
In Europe we have EOBD, introduced in 2001 for petrol cars and 2004 for diesels, with a lot of exceptions. The last cars that became compliant were large commercial vans with a diesel engine on 1st January 2007.\
So, this car will have the 16-pin diagnostic connector (because that's cheaper for Ford to build), but it's not compliant with EOBD.
Old Mar 7, 2010 | 08:20 AM
car.crash's Avatar
car.crash
I stupidly plugged a obd scanner into my mondeo and let's say it was not very well afterwards. Just simply plugging it in messed alot of things up and caused the injectors to be reprogramed according to a friend who had to fix it. The car simply would not run I was a 2002 tdci mondeo aswell.
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
