fiesta imobliser
Old Mar 6, 2010 | 11:01 AM
paul123's Avatar
paul123
Default fiesta imobliser
the imobiliser on my fiesta 1.4 16v r reg keeps kicking in had the ecu tested came back fine there must be a way to disable it how can i do it i have only one key a black one so cannot reset it .this problem only seems to happen when cold .please help it is so frustrating
Old Mar 6, 2010 | 11:23 AM
Sometimes static electricity on the key can affect it, so worth rubbing key for a few minutes with wet cloth, removes the static, have known it work before, though that was for ones that wouldn't work to start with, worth a free go though.
Old Mar 6, 2010 | 04:12 PM
paul123's Avatar
paul123
you posted same answer before i have tryed it it has no effect any other ideas or is there a way to disable imobiliser
Old Mar 6, 2010 | 04:43 PM
They can be disabled, as everything can, but never done a festa with pats problem disabling wise so can't comment.
The system is fully interagateable though so dealer should be able to pinpoint almost instantly on machine.
Old Mar 7, 2010 | 12:02 PM
paul123's Avatar
paul123
i took it to a garage they said it was a blanket computer problem and cannot put it down to aparticular thing and they wanted to change every thing at a cost of a thousand pounds i think it is just a sensor problem but what one could it be ?
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
