what head gasket COSWORTH
what head gasket shld i run if head and block`s been skimmed? will i get away with group A or shld i go thicker 2 lower comp??
Unless going for seriously mental power where you need shit loads of boost, keep the std cr.
Up to 500bhp I would use a group a YB 0611, about £55, esp if 2wd, if 4wd(200 block) a std escos one is fine.
