Focus 2008 td accident damaged
Old Mar 4, 2010 | 03:11 PM
sonic0178's Avatar
sonic0178
Default Focus 2008 td accident damaged
I have bought a 2008 ford focus new shape the car is accident damaged on the front driver side of the car.The car wont start.It is a durateq engine I have looked for a fuel cut of switch but I cannot find one even though the manual says durateq engines have one.The dash board also says engine malfunction then it says power steering malfunction could it be because the belt is not fitted because it broke in the accident?Can someone please help?
Old Mar 5, 2010 | 03:48 PM
JonathanJ's Avatar
JonathanJ
If it is a diesel then it is a duratorq if a petrol duratec , if a diesel then no fuel cutoff , and also it would have electric power steering which happens to be fitted under the os front bumper .... first thing to go in an accident is the pump and associated wiring.
I would say it may have another issue causing engine not to run , try keying off pressing and holding the trip button in then keying to position2 and continue holding trip button in until the dash enters the self test mode , release button then tap button until the DTC's are shown , make a note then post them and will see if they make any sense .
Old Mar 5, 2010 | 04:25 PM
sonic0178's Avatar
sonic0178
Sorry to sound thick when u say keying off do u mean in the off position and what is the trip button? Sonia
Old Mar 5, 2010 | 05:21 PM
JonathanJ's Avatar
JonathanJ
yes to the key off question , and the trip button on the cluster , the little black button you would use to reset the mileometer .
Old Mar 6, 2010 | 10:59 AM
sonic0178's Avatar
sonic0178
Right I hope this makes sense.
Rom level 0203
Num target Rom 0203
Num EEPROM lul 0001
Manufacture start 6x
Chemer Module 0n 7 50hz,50%
Manufacture 0018
DTC#1 D900
2 E510
3 A286
4 9681
D 147
Speedo gauge 0041
Tacho gauge 0046
Od o roll 0
fuel ADI input 140 active
Engine temp 28c
Temp gauge 0055
Batterie
Pats key flags 5c
A/D input 00 87
1 9C
2 AE
3 FF
4 6A
5 15
Port 1B
B00
Eof
K05
LFF
M14
P22
S11
TFD
U00
V00
D3B
Dersonaity 01 00
2 00
3 00
4 00
I have also tried aOBD2 memoscan and it just says error..
Any help would be so helpful.Thankyou Sonia
Cos500
Sep 16, 2015 09:50 PM
little bram
Sep 10, 2015 10:45 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
