Focus ST Key programming?
Old Mar 2, 2010 | 06:50 PM
jan8p's Avatar
jan8p
Default Focus ST Key programming?
Hi all,
I've purchased a new remote key off ebay and had it cut.
I've programmed the remote locking/unlocking from my previous remote key and that's working fine.
I now am trying to program the key to start the car but cannot seem to get it to work!
I've followed all the instructions i've found and still nothing!
I have 2 working keys - one non remote key (with red chip) and one remote key.
Anybody any tips? Is it even possible to code a new key to the immobiliser on an ST?
Cheers for any help
Old Mar 2, 2010 | 09:54 PM
James998's Avatar
James998
Ford dealer, or independant garage with ford diagnostic equipment im afraid mate.
Old Mar 3, 2010 | 08:31 PM
jan8p's Avatar
jan8p
Ah damn
Thanks anyway!
Old Mar 3, 2010 | 08:47 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I know you've programmed the key to work remotely, but I have a how to guide to programme to the immobilser that you could try.
MK1 st
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals.
Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B).
Insert key A into ignition switch.
Turn ignition switch to position II. Wait 1 second.
Switch ignition OFF. Remove key A.
Insert key B into ignition switch within 5 seconds.
Switch ignition OFF. Remove key B.
Within 10 seconds:
Insert key to be programmed into ignition switch.
Turn ignition switch to position II. Wait 4 seconds.
Switch ignition OFF. Wait 5 seconds.
Start engine.
If engine does not start and clock LED flashes:
Switch ignition ON. Wait at least 20 seconds.
Switch ignition OFF. Repeat programming procedure.
Repeat above procedure to program remaining keys.
Keys can also be programmed using diagnostic equipment.
NOTE: A maximum of 8 keys can be programmed, including a maximum of 4 with remote control.
NOTE: If the system is in spare key programming 'disabled' mode, the above procedure will not work. Diagnostic
equipment will be required to change to spare key programming 'enabled' mode.
Old Jun 29, 2010 | 08:04 AM
completelocks's Avatar
completelocks
Locksmith
Originally Posted by jan8p
Hi all,
Cheers for any help
If you have two working keys then you can add a key to the system as posted above.
Failing that, you dont need to go to a ford dealer, in fact thats the last thing you wanna do, unless you know someone who works there. Look for an auto locksmith. It takes less than 5 mins to do, and wont cost the earth.
liamT74
Sep 23, 2015 10:24 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Iain Mac
Sep 13, 2015 09:16 PM
NC53
Sep 13, 2015 03:05 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
