rev counter (escort cosworth)
does any one know where the rev counter on the escort cosworth picks up its supply from under the bonnet and what colour wire the supply is. thanks
If the early BT escos is like the sapphy, then it is on the negative of the coil, via a green wire, the ST escos I would imagine but don't know is ecu fed ?
JoeyBoyden
18-08-2015 05:56 PM
cozzy jeff
14-08-2015 05:46 PM
