mk4 Speedo
Old Feb 28, 2010 | 11:54 AM
Mart_'s Avatar
Mart_
Default mk4 Speedo
hi, iv bought a escort mk4 1.6 cvh and the speedo is'nt working, ive tested the my speedo in an rs turbo and the work, and ive also changed tha cale, and the problem is still there
Has anybody got any idea of whhat it might be???
Old Feb 28, 2010 | 12:37 PM
If the cable is ok and the speedo works this leaves the other end of the cable, ie gearbox end, sometimes the teeth on the drive pinion wear, so need to look at this, whilst there spin the cable with your fingers of a drill and you will see the speedo register, if it doesn't spin the other way, going the wrong way will cause no damage.
Old Feb 28, 2010 | 01:24 PM
Mart_'s Avatar
Mart_
well ive just taken the pinion out and its worn so i put another 1 in off my bros rs turbo and its striped that 1, so ive looked a lil on tha net and decided the bearing hae stoped working so a new box is needed!
Old Feb 28, 2010 | 01:45 PM
Yes if the diff bearings have dropped or become very worn it will do this.
Old Feb 28, 2010 | 05:10 PM
Mart_'s Avatar
Mart_
well thank you very much for youre help
cossie brad
Sep 29, 2015 02:38 PM
streetracer
Sep 24, 2015 08:14 PM
roomey
Sep 19, 2015 08:40 AM
Bransby
Sep 14, 2015 08:54 PM
bassboy
Sep 10, 2015 08:54 PM
