Anybody done a 330 conversion themselves???
Old Oct 24, 2003 | 03:08 PM
CosRush's Avatar
CosRush
Default Anybody done a 330 conversion themselves???
Ive got all the parts for it, but am not sure about whether it will be setup ok after fitting.
Boost is simple enough, but what about fuel pressure?
Is it likely it would need adjusting or should it stay at normal?
If it does indeed look risky then i wil take it to the specialist who supplied me the conversion but that will have to be next year now (if i can wait!!!)
Any comments?
Old Oct 24, 2003 | 03:15 PM
flashpoint's Avatar
flashpoint
If you have all the parts, why not fit them, get the car running and take it to your nearest rolling road, and get it set up
At least they would be able to sort out any small problems
Steve
Old Oct 24, 2003 | 07:10 PM
steveRS's Avatar
steveRS
thats what i did ( fitted myself) then set up on rollers
steveRS
Old Oct 24, 2003 | 08:05 PM
CosRush's Avatar
CosRush
Cheers Fella's.
Is it going to be ok to take it to a rolling road who aren't necessarily Cosworth specialists???
Ive got one about 20 minutes away, but dont know if they know about cosworths.
Once the kit is on, is it just a case of setting the correct boost, co???
How is the fuel pressure affected when switching to Dark Greens?
Old Oct 25, 2003 | 10:29 AM
steveRS's Avatar
steveRS
the fuel pressure on mine from stage 1 to stage 3 wasnt changed it was the fuel mix that was diff.
regards
steve
Old Oct 25, 2003 | 03:10 PM
CosRush's Avatar
CosRush
Steve,
Do you mean the Co? or something else???
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
