mk4 convertible hood
Old Mar 12, 2004 | 09:39 PM
Default mk4 convertible hood
can anyone give me any advice or info on fitting the hood. the frame and linning is already fitted i just need to fit the leather part and havent got a clue on how to do it
Old Mar 16, 2004 | 11:16 AM
CabrioTurbo's Avatar
CabrioTurbo
Its not easy at all if your doing it yourself and have never done one before.. infact even now after seeing someone do mine i wouldnt like to attrempt it myself! your best getting someone to fit it for you!
(or buy the hood off my old cab which was 2 days old before it got crashed )
CheeRS
Phil
Old Mar 16, 2004 | 03:37 PM
Having taken off and replaced an Astra Hood, I believe what you do is fit the new hood material. Then offer up the window and cut out the hole for the window when the hood is locked in position, but remember to put some sealant around the rubber of the window.
Old Mar 16, 2004 | 03:45 PM
CabrioTurbo
pmsl offer up the window and cut it unevenly
seriously though it can be done but its FAR too much hastle! you will need to remove the strip that holds down the front of the hood and fold the new one over and screw it back down also the sides of the hood (where the material folds over and under the runner bit isnt exactly easy to fit!)
The main problem you have is with tentioning the hood as it will sag after a while and look shit
Old Mar 16, 2004 | 07:09 PM
cheers for that im just gonna pay someone to fit it saves fookin about
Oranoco
41
Feb 11, 2016 01:28 PM
mondeomark
Sep 28, 2015 06:28 AM
streetracer
Sep 24, 2015 08:14 PM
bassboy
Sep 10, 2015 08:54 PM
Neil Clark
Sep 8, 2015 07:06 PM
