Torque setting for 4x4 Cossie Engine Mounts
Old Feb 11, 2010 | 04:16 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default Torque setting for 4x4 Cossie Engine Mounts
as above. just checking to see if there is a torque setting as i dont want to go through another set of front drive shafts and as there is both nuts on the top and bottom of my collins engine mounts, i thought id best ask. cheeRS
Old Feb 11, 2010 | 07:57 PM
Tight!!, I never bother with most of them, just the important ones, don't need to be mentally tight so long as new lock nut used.
Old Feb 12, 2010 | 01:42 PM
dakunia's Avatar
dakunia
As described on Cosworth Workshop manual:
Nuts - engine mounting bracket to engine mounting - 70 to 90 Nm.
Engine mounting to cross member nut - 50 to 70 Nm.
cheers
m
Old Feb 12, 2010 | 05:00 PM
kosienutter
thanks ever so guys.
cheeRS
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
