help help charging problem
Old Feb 6, 2010 | 05:36 PM
beardo1's Avatar
beardo1
Default help help charging problem
ive put a new alternator on my mk4 diesel van and still not charging can any one help me its not the battery cause thats knew aswell cheers mike
Old Feb 6, 2010 | 05:42 PM
fathead's Avatar
fathead
Have you check or replased the altinater wires that you bolt upto it cause they sometimes break somewhere up the line of wire
Old Feb 6, 2010 | 06:48 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
have ya checked the cables are on properly
Old Feb 6, 2010 | 07:25 PM
peanut_coz's Avatar
peanut_coz
My mate had the same problem with his cossie. Turned out the bulb for battery icon had blown in dash and apparently that part of the charging system, hence the circuit was broke.
Dont know if it could be same on your van but worth chaecking ?
Old Feb 6, 2010 | 07:35 PM
martysmartie's Avatar
martysmartie
As said make sure you have battery light, btw on Cosworths this is common for wire to break, will still charge if revved hard enough as field windings get excited. If you have battery light and it goes out once running it will be cable from alt to batt. Probably there was nothing wrong with old Alt.
Relised that it's Diesel as well make sure you haven't mixed cables as Diesels normally use one terminal to feed tacho. (If applicable)
Martin
Old Feb 6, 2010 | 08:11 PM
What is the charge rate ?, put the car up on ramps at front connect metre to live at solenoid and earth on metal, with the blue wire OFF start the van, then get underneath, and just watch the metre, now briefly touch a LIVE onto the alternator terminal marked IND, this is where the dash warning bulb connects to, it should then energise and start charging, if revved high enough it will start the charge cycle as well, as they have a resistor built in for a fail safe, if after touching a live onto IND it does nto start outputting even though it is rotating and connected ok it is duff.
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
