Running in smoke ?
Old Jan 31, 2010 | 12:55 PM
mattman1234's Avatar
mattman1234
Default Running in smoke ?
Running in cosy engine at mo,just a bit concerned,when i start car from cold,no smoke,when blipping no smoke,if i leave car ticking over for 5 minutes or so,then give it a rev,a puff of blue smoke,clears straight away.no smoke when driving,or on overrun,only when left ticking over for a while.Any ideas,could the turbo be letting by,could the oil feed union be to big in top of turbo.Its a new turbo.The only thing that i did not change was the valves.I still have a crap mineral oil in at the mo.
Any ideas,thanks matt
Old Feb 1, 2010 | 05:29 PM
mattman1234
what size should the hole be in the turbo union ?
Old Feb 1, 2010 | 06:37 PM
Did you do new guides ?, it doesn't sound to bad if only whilst idling, if running a tad rich(bad) it will cause a little smoke esp running in, you are running it in properly, ie not babying it everywhere ?
If you suspect the turbo, look in the inlet pipes, should be nothing more than faint mist of oil in there if anything.
Old Feb 1, 2010 | 08:11 PM
mattman1234
just driving it as if were a non turbo car,but keeping off boost,did have new guides,but left the valves,i'm wondering if they were a bit to worn
Old Feb 2, 2010 | 04:19 PM
Whoever did the headwork would presumably have told you if the valves were shagged.
Why you keeping off the boost, how many miles has it done, what oil you using ?
Old Feb 2, 2010 | 06:36 PM
mattman1234
was told not to boost,done 500 so far ,using a halfords own mineral oil.Is a well known cosy tuner i am dealing with at mo in romford.
Old Feb 2, 2010 | 08:13 PM
A small amount of boost won't hurt, but more important, use plenty of revs, I am at full throttle by 500 for brief periods.
S3an
Sep 26, 2015 11:39 PM
dombanks
Sep 21, 2015 08:38 PM
S3an
13
Sep 13, 2015 10:01 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
turbowag
Sep 3, 2015 08:07 AM
