MSD chip advice ?
Old Jan 29, 2010 | 08:49 PM
mattman1234's Avatar
mattman1234
Default MSD chip advice ?
I,m thinking about using an msd chip,its going to be a 380bhp chip(hopefully).
How accurate are the chips,ie,will it need much setting up afterwards on the rollers.I have spoken to them and given them all the specs ,low comps,t34 etc........My main worry is detonation,has anyone found that their car detonated after an msd chip was installed,without any adjustments afterwards,(assuming the engine was in order before hand).
they did say if any probs i could send the chip back to be altered.The car is a caterham 7 type car,so only weighs about 700kg.
any comments appreciated
Matt
Old Jan 29, 2010 | 08:55 PM
1223456's Avatar
1223456
The people who assembled my bottom end had a cossie there which had one of their generic chips, they didnt say much about it when i asked other than it was smooth and if anything a bit safe. I would recommend taking to them for a proper setup as you wont go far wrong, they have a faultless reputation.
Old Jan 29, 2010 | 09:00 PM
mattman1234
i did want them to set it up,but they said the power to weight ratio was to much,and would not take the car out on the road
Old Jan 29, 2010 | 09:13 PM
1223456's Avatar
1223456
How you spoke to IA motorsport? I think they are near you and they have a r/r
Old Jan 29, 2010 | 09:21 PM
mattman1234
just had a look will give them a call
cheers
Old Jan 29, 2010 | 09:34 PM
KSA-Cossie's Avatar
KSA-Cossie
I just checked my afr when i first fitted mine but did go down to blackpool for a check up later.
Old Jan 30, 2010 | 06:17 PM
I can understand the apprehension, as it's entrusted to them they carry the can.
As said there are other people who can set these ecu's up.
A off the shelf chip can never really, unless by pure luck, be as good as a mapping session, that is tailored to your car only, msd will use thier experience of all things cossie to get you a ace chip, though thinking sensibly it would if anything have to err on the safety side.
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
