NEED HELP!
Old Jan 27, 2010 | 09:40 PM
matt24680's Avatar
matt24680
Default NEED HELP!
hi there i reciently tried fitting a cd player that i had in my focus to a friends toyota corrola and when i fitted it i noticed it kept on blowing the main fuse in the fuse box which is 15amp and i tried changing the fuse on the back of the cd player and it made no difference what do i need to do??will i put a higher fuse in the fusebox?
thanks matthew
Old Jan 27, 2010 | 09:45 PM
saph_Al's Avatar
saph_Al
DONT just put a higher rating of fuse in , if it's blowin it's for a reson , Have you deffo got a good solid earth ? check your powers r ok and that there correctly wired , have seen peoplr use the illumination wire as an earth and produce simular effects . I assume it didnt have this problem when it was in your focus ?
Old Jan 27, 2010 | 09:51 PM
matt24680's Avatar
matt24680
hi there i amnt very good at wiring sorry do you mean the earth on the car or the cd player?do i need to change back the fuse in the cd player?what the illumination wire?the car will work with a tape player with 15 amp fuse so the power sources shud b ok. sorry for all th questions
Old Jan 27, 2010 | 10:24 PM
matt24680's Avatar
matt24680
hi sorry forgot to mention no i didnt have this problem in the focus
Old Jan 28, 2010 | 03:53 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
the illumination wird is usually the orange one. I once accidentally contacted the 2 power wires (yellow and red) and blew my central locking fuse. Id check that the wires are not in contact with anything metal behind the dash. You could have shorted on something. Put the orinal fuse back into the CD player.
Old Jan 28, 2010 | 12:53 PM
martysmartie's Avatar
martysmartie
You had another thread with same problem, as said putting a higher rating fuse will do NOTHING as it is blowing for a reason most defo a short circuit. Illumination wire takes a feed from lights so when switched on unit lights as well and as said normally orange.
Fuse is fine, it just protects that feed 15A is plenty.
It needs to be earthed and the wire for that will be black.
Martin
Old Jan 28, 2010 | 04:36 PM
matt24680's Avatar
matt24680
hi there thanks for the help i remebred now that there was a wire wrapped round some metal on the focus before and i totaly forgot about it so it will be the earth thats the problem ?will i just ground the illumination wire is this the orange 1 ?sorry for being so anoying with the questions
Old Jan 28, 2010 | 05:35 PM
martysmartie
It wont be "Wrapped" it will be bolted via a connector to a earth point. The illumination wire is not an earth it's a live feed which should be supplied by the lights so when they are switched on the unit illuminates as well.
Also best of having one thread rather than multiple in different sections.
Martin
Old Jan 28, 2010 | 06:05 PM
matt24680's Avatar
matt24680
hi there so i have connected the 2 plastic box clip things to the toyota with a toyota adapter would the illumination wire not be in there?if its not should there be a place where i can just connect it or would i need to tap into a line for it? in my focus i dont think the illumination wire was connected well if it wasnt in the box clips and just went on when i turned on the ignition. and there was no earth bolted on but if i did bolt it would it have to be an earthing point or can it just be a bit of metal?
what colour is the illumination and earth?
Old Jan 28, 2010 | 07:22 PM
saph_Al's Avatar
saph_Al
ok best to take it out and start again ,
1 black wire to good earth .
2 red to constant battery feed
3 yellow to ingnition live
dont worry about the illumination wire for now it will work fine with out .
As martian said 10-15 amp in the back is the norm it should say in the cd play what to put in . you can get connectors to plug straight in that take the guess work out of fittin head units if your not to hot with your wires .
Old Jan 28, 2010 | 07:25 PM
saph_Al's Avatar
saph_Al
the earth will be on the toyota multiplug dont know what colour it's gonna be but may be a hevey gauge brown or black . as i said it may be just as easy to go to halfrauds with and ask for a connector to fit it
