injector
Old Jan 26, 2010 | 06:28 PM
raycov's Avatar
raycov
Default injector
when you put a mutimeter on a injector connecter like i have just done,one terminal reads a constant 11 volts and the other terminal reads nothing,when you then turn the engine over should there be a pulse to the one that reads nothing.
cheers
Old Jan 27, 2010 | 06:34 AM
oldford's Avatar
oldford
When the engine is off both sides should read equal to the battery voltage.
Disconnect connector and measure resistance. Probably open, so injector defect.
Old Jan 27, 2010 | 07:59 AM
martysmartie's Avatar
martysmartie
The injectors do NOT read equal both sides it should read 12V on live side, the earth side is switched by ECU so no power.
Martin
Old Jan 27, 2010 | 08:13 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
most multimaters will not pick up on the injector pulse
raycov's Avatar
raycov
so do get a pulse on when the engine turns over on the earth side or is it just a earth if you now what i mean
cheers
Old Jan 27, 2010 | 08:33 AM
martysmartie
Yes the earth side is pulsed but will be to fast for a meter to register as said if thats what your trying to do. If you want an easy test connect a light bulb opposed to injector.
Martin
Old Jan 27, 2010 | 05:51 PM
DON'T whatever you do connect a light bulb, injector drivers could be burnt out if the wrong bulb is used, take the rail off with the injectors, disconnect coil and turn over, fuel will spray from any injectors getting the required feed.
A NOID light is the thing to insert, or if you have osciliscope that will easily capture the signal, but most don't have this lying around!!
Old Jan 27, 2010 | 06:59 PM
saph_Al's Avatar
saph_Al
Yeah as above it will read dead on one side and recive a flashed earth signal to fire the injector . i have a set of noid lights u can borrow if your local to me
Old Jan 29, 2010 | 09:41 AM
raycov's Avatar
raycov
still problems,when i put the fuel gauge in the fuel line it whent straight up to 3.5 bar which is spot on,then when i stopped turning it over it dropped of to nought is this correct,or should the pessure hold,the other thing is that when i try to start it the voltage needle on my gauge goes down to nought aswell and then,the needle goes back up to normal when you stop turning it over
what do you reckon
Old Jan 29, 2010 | 10:47 AM
EFI will normally hold pressure better than this, due to the sprung loaded valve, that is the pressure reg closing the flow off, but so long as it is working and maintaining under load, the correct fuel pressure should be ok.
If the volt gauge has been wired to the number 1 position of the ignition switch(accessory) then it will drop out in the start position as the start position cuts power to accessory position normally, rewiring to number 2 pos will make it run 100% of the time but I wouldn't bother.
Old Jan 29, 2010 | 12:05 PM
raycov's Avatar
raycov
cheers mate
did you install a tech edge system once,and have you still got it
Old Jan 30, 2010 | 06:21 PM
Yes I run Tech Edge, or rather I have it all hooked up, but I run purely mapped position with ecu, CL isn't needed if mapped correctly.
Old Jan 31, 2010 | 11:27 AM
JTECH James
Passion for Fords!
so all the manufacturers from 92 onwards who spend millions in development cant map then?
Old Feb 1, 2010 | 07:24 PM
Why are you talking of something not even related james ?
I've never said manufacturers can't map correctly have I, please show me where ?
Mapping a modded engine is not the same as mapping for a mass produced engine that has to put up with so many variables, if the makers mapping was top notch MSD would have of business, with chips etc, that exploit the less than ideal mapping, oddly enough 92 co incides with cats becoming popular, it was to do with emissions.
What I stated clearly was that a correctly INDIVIDUALLY mapped car will likely show no discernable difference in mpg, mpg and emissions don't always go hand in hand.
Ask stu why the M5 has a ecu that adjusts itself, surely you know more than BMW motorsport, or does this yet AGAIN show there are gains to be had.
Old Feb 1, 2010 | 07:39 PM
JTECH James
Passion for Fords!
reading this thread from top to tail how do you know it isnt a 92 car that needs cat testing?
there can be a great need for closed loop. regadless of mapping, manufacturer's dont fit it for fun.
you clearly said "closed loop isnt needed if mapped correctly" and i disagree.
you always dive in saying its not needed...this thread has nothing whatsoever to do with closed loop and yet your favorite comment pops up again.
lol at "why am I talking of something not even related"...oh the irony
the m5 also has a sophisticated closed loop system, but i guess it doesnt need it? as it is very well mapped
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
