Where is MK4 XR3I EFI ECT Sensor?
Old Jan 26, 2010 | 04:47 PM
jedi0_3's Avatar
jedi0_3
Default Where is MK4 XR3I EFI ECT Sensor?
Evening.
Probably a dumb ass question but according to the Haynes manual I should have an Engine Coolant Temperature(ECT) sensor screwed into the cylinder block below the inlet manifold but I cannot see anything on my late Mk4 1990 EFI XR3i.
Does anyone have any ideas?
Thanks
Old Jan 26, 2010 | 05:11 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it's on the inlet manifold, but underneath. not on the block.
take manifold off and you'll see it, or from underneath you should see it, follow a wire off the injector wiring harness to under the mani, black plug IIRC
Old Jan 26, 2010 | 07:35 PM
Toe Knee's Avatar
Toe Knee
As above its under the inlet, and a biatch to see!!! just next too it is a coolant pipe too if that helps find it!
Old Jan 27, 2010 | 07:16 AM
jedi0_3's Avatar
jedi0_3
Thanks guys, will have a look today!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
fordrallycar
Sep 30, 2015 07:57 PM
