Abs warning light????
Old Jan 25, 2010 | 10:28 PM
rslove's Avatar
rslove
Default Abs warning light????
Hello iv got a escort rs s2 and the abs warning light has come on even tho the abs has been taken off!
Is it a wire come loose?? If so does any one know which one??
Old Jan 25, 2010 | 10:33 PM
liam-rst's Avatar
liam-rst
shit happens
if abs been removed m8 just take the bulb out,
Old Jan 27, 2010 | 08:59 AM
rslove's Avatar
rslove
dont really wanna take bulb out the abs light and the liw level light is on but fluid is at normal level. they were both off till couple of weeks ago when they poped up togeher.
Old Jan 27, 2010 | 09:17 AM
AndyST's Avatar
AndyST
If you pull the plug off the fluid reservoir sensor, does the light go out?
Old Jan 27, 2010 | 10:25 AM
rslove's Avatar
rslove
will go check now
Old Jan 27, 2010 | 10:50 AM
rslove's Avatar
rslove
just took the plug of the res. and the red brake light went out, but the abs light stays on.
Old Jan 27, 2010 | 10:53 AM
Cossy Mike's Avatar
Cossy Mike
abs sensors are simply just switches that run on the abs belts so if the belt snaps the switch opens. If they are still there tape them up or cut the plug off and join the wires together.
Old Jan 27, 2010 | 10:58 AM
rslove's Avatar
rslove
the abs has been taken off so not sure which are the wires to join
Old Feb 2, 2010 | 02:34 PM
rslove's Avatar
rslove
Sorted it had carpet out to check 4 leaks! and noticed little bit of bare wire on the cable from the handbrake switch taped it up sorted must have been shortin on floor!
cheers
Old Feb 2, 2010 | 03:04 PM
AndyST's Avatar
AndyST
Cool, forgot the ABS light came on with the h/brake.
muzzman1
Sep 30, 2015 08:59 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
