Mk3 Fiesta Brake Servo
Old Jan 24, 2010 | 10:25 PM
JamesyRS's Avatar
JamesyRS
Default Mk3 Fiesta Brake Servo
Hi guys ive had problems with the brakes on my fiesta. I had a run in my Escort RS the other day and decided to turn off ignition and hit brakes as the servo wouldnt be working. As I suspected my fiesta brakes while runnin the same way my Rs did while turned off. You know the jump on the pedal to stop stuff so was wondering if my fiesta could be needing a servo? or does anyone know where else to look before the servo? vacuum pipe dont seem clogged or anything so took it to be servo but again dont want to go changing it if it aint that any help will be appreciated guys cheers
Old Jan 24, 2010 | 10:38 PM
AndyST's Avatar
AndyST
Standard servo test mate- engine off, pump the pedal 5 times, then press the pedal again whilst starting the engine, you should feel the pedal go down if the servo's working ok.
Old Jan 25, 2010 | 01:31 PM
Even better test pump the pedal fast with the engine idling the idle speed should go up.
Old Jan 25, 2010 | 06:10 PM
JamesyRS's Avatar
JamesyRS
thanks guys Ive came to conclusion its the servo so sourced one from the bay hope it sorts it out thanks again for the quick helpful replies!!
155lee
Sep 6, 2016 11:10 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Brian
Sep 11, 2015 08:06 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
