Focus: delay accelerating when changing gear
Old Jan 23, 2010 | 03:54 PM
Barrett's Avatar
Barrett
Default Focus: delay accelerating when changing gear
Hi
Ford focus 1.6 zetec 2001. It was recently serviced but after changing gear when you put your foot on the accelerator pedal there is a delay before acceleration picks up (there is a sort of surge before acceleration a bit like in an automatic car). It doesn't constantly happen and I notice it more changing to third fourth and fifth. It also happens if I take my foot off the accelerator to slow a bit and then step on it - it doesn't respond. I have searched posts but can't find a similar problem, it doesn't loose power as such and the speedo doesn't drop or anything like that. Could it be the timing belt? would that produce these symptoms? or does the cambelt need changing (it is coming up to the time when this has to be changed anyway).
Last edited by Barrett; Jan 29, 2010 at 12:45 PM. Reason: learned a bit more about the problem
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
landaqmabba
Sep 15, 2015 07:16 PM
marky_g
Sep 12, 2015 04:26 PM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
