2003 Focus 1.6 engine light
Old Jan 22, 2010 | 07:25 PM
Trapper's Avatar
Trapper
Default 2003 Focus 1.6 engine light
Hello,
First post, and I'm afraid it's a problem.
I've got a lovely 52 plate 1.6 petrol Focus Ghia. Fallen for it totally.
It's had a full service last week, passed the MOT with flying colours.
Drove into work today, and it was fine. Left it parked for three hours (it was chucking it down) and nipped out to the local shops.
As soon as I turned it on the engine warning light came on, and stayed on.
I've tried the old diagnostics with the tripometer on engine start, and no error code is being given - just says none.
The engine is running fine, revving as normal, no backfires, gear changes are smooth.
Oil's fine and all the fluids are bang on.
Obviously she's going back to the dealer under warranty (they also need to fix a few niggles like the 12v sockets aren't working).
Just as bit of peace of mind does anyone know what this could be? All I've read is point towards the sparkplugs (although I'd hope they'd have been checked last week during the service!!)
Thanks for any advice you folks have.
Matt
Old Jan 22, 2010 | 07:27 PM
AndyST's Avatar
AndyST
You really need a diagnostic run on it mate to get any fault codes that are stored.
Old Jan 22, 2010 | 07:31 PM
Tank Mike's Avatar
Tank Mike
My cash is on the O2 sensor, also known as the HUGO or LAMBDA sensor
Old Jan 22, 2010 | 08:01 PM
Trapper's Avatar
Trapper
Nice one.
Thanks for the advice. From the sounds of a failing O2 sensor, I think my old Ka had one for the last two years of her life!
Old Jan 27, 2010 | 05:22 PM
Trapper's Avatar
Trapper
As you said post cat O2 sensor.
Thanks for the heads up, saved me worrying until I could get it to a garage!
Old Jan 27, 2010 | 05:33 PM
pani_k's Avatar
pani_k
PassionFORD Member
Almost certainly lambda sensor as mentioned above. As for the 12V socket, check the fuses behind the glovebox. Can't remember number off the top of my head number 36 or 37 or 46 or 47 I think. Underside of the glovebox tells you should be 15A I think in there. I've stuck a 25A in because my bloody 12V air compressor keeps blowing them on the initial plug in.
RUBY123
Oct 22, 2023 12:04 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
taylora1409
Aug 12, 2015 12:06 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
