2001 focus losing power
Old Jan 22, 2010 | 04:21 PM
Missjordy:D's Avatar
Missjordy:D
Default 2001 focus losing power
Hi i have a 2001 1.8 petrol zetec focus, This las 2 months it has been giving me a problem that no one can figure out..., After a certain driving distance the car loses all power and stutters for a while until the car goes again if i let the car sit maybe 10-15 minutes the car will go perfectly for another while. The problem has got worse over the last month, Ive had all air, fuel and oil filter changed and a new cat converter put on and the problem is still occouring. Need HELP
Thanks Jordy
Old Jan 22, 2010 | 07:13 PM
Try driving it with the fuel cap off(just to see), if the tank vent is blocked it causes a vacuum as there is no longer breathing holes in the caps, could be causing enough vacuum in the tank to deprive engine of fuel.
Old Jan 22, 2010 | 11:00 PM
Missjordy:D
Thanks tabetha for ur reply i have fuel cap off havent drive the car yet so i will get a drive in it and c if that cure's it and let ya kno..., Thanks again
Old Jan 22, 2010 | 11:25 PM
Duratec190's Avatar
Duratec190
Is engine management light on?? possibly a lambda sensor! need to check for diagnostic trouble codes (DTC's)
Old Jan 23, 2010 | 06:12 PM
Missjordy:D
Na there is no engine managment lights ever coming on so i dunno wat it is thanks m8
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
