mk3 mondeo 2.0 duratec prolem
Old Jan 21, 2010 | 07:01 PM
jonny514mcl's Avatar
jonny514mcl
Default mk3 mondeo 2.0 duratec prolem
ok ive a strange gurggle noise comming from behind the dash whats wrong
temp normal never goes over half
coolant level fine
oil level fine
fan comes on more often than normal but temp hand never goes above half
Old Jan 22, 2010 | 07:42 PM
Are yo using any water/coolant ?, is it a sound more like rushing water ?, if so I notice this on me dads mondy(mk1) but nothing necessarily wrong, just a characteristic if all else right.
Old Jan 22, 2010 | 07:49 PM
Ginger Will's Avatar
Ginger Will
I get this on a fiesta, never had a problem and the engine warms normally etc..
Old Jan 28, 2010 | 06:06 PM
ronin_hungary's Avatar
ronin_hungary
I have had similar noises it was the A/C system. When I have turned it off, then the sound stopped. Took it to A/C specialist then for like 40 GBP, A/C cleaning, refill etc. and it stopped.
1 more thing. I have had a head gasket blown in my off-topic car.
The temp NEVER went above half. Thermostat was new, everything seemed normal, except a few drops of coolant from the overflow bottle. The end of the story was that later it started to "burble" the water by pushing the air into the water chamber (not sucking it or whatever). Solution was head gasket repair...
Hope these help...
Cheers,
R.
Old Jan 28, 2010 | 06:08 PM
Fiddy's Avatar
Fiddy
Was gona say is it not air con or heater related ?
Old Jan 29, 2010 | 11:37 AM
You can get this noise WITHOUT air con, as my dads does it(used to be mine), and the AC is disconnected and empty.
Old Jan 29, 2010 | 12:35 PM
ronin_hungary
Then I would stick to my story #2..... OR.....
Maybe some air trapped inside the engine cooling system. (That would be lucky). It does not hurt to change the coolant and might as well do a cooling system cleaning (i usually do once in every 2 years on my cars) as a last hope for resolving the issue. If not, back story #2...
Hope this helps...
Cheers,
R.
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
The Enigma
Sep 29, 2015 10:31 AM
