Spark plugs
Old Jan 18, 2010 | 01:03 PM
dave12345's Avatar
dave12345
Default Spark plugs
Hi gents,
I need to replace the spark plugs on my 1.8 petrol zetec mondeo 2002. Do I have to purchase the titanium plugs as stated (they are very pricey) or can I use standard plugs. Can you advise the gap that needs setting and the best place to buy the plugs.
Regards
London
Old Jan 18, 2010 | 02:00 PM
cossiejay's Avatar
cossiejay
i would replace like for like they use them for a reason motor factors are the cheapest
Old Jan 18, 2010 | 02:54 PM
If you want to keep the long service intervals I would use the recommended ones, but yest there are cheaper ones that will work just as well, won't last as well though.
Old Jan 18, 2010 | 03:56 PM
phil_focus's Avatar
phil_focus
i've always used ngk platinums in my 1.8 and 2l zetec e engines as have others i know and found to perform the best. i'venever had any issues with them and my cars have always run spot on and performed brilliantly with them so i recomend them.
i've always gapped them to 1mm according to my 2000 manual but a mate with more upto date info says these can be gapped to 1.3mm which is far better than the motorcraft ones at 1mm.
Old Jan 24, 2010 | 08:59 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
NGK Platinums all the way
Matt
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
