xenon lights on high beam
Old Jan 15, 2010 | 06:16 PM
chugs76's Avatar
chugs76
Default xenon lights on high beam
Hi folks hope someone can help me with this. I have a 06 ST3 Focus with xeno headlights. When using the high beam the 2nd filament in the xenon lamp stays lit when switching back to main beam. Have taken to Ford for a fix and they have re-aligned the lights but problem still occurs. Please help
Old Jan 16, 2010 | 11:05 AM
Confused, do you mean the dip stays lit on main beam, if so it won't be a aligment fault.
Do you mean HID when you say xenon ?
Old Jan 16, 2010 | 04:59 PM
chugs76's Avatar
chugs76
Hi Im not sure about HID they are standard ST3 lights. When u flash the lights the 2n filament in the xenon lamp stays on high beam. Hope this helps.
Old Jan 16, 2010 | 07:49 PM
saph_Al's Avatar
saph_Al
Hi ya mate pritty sure there a single filiment but the have a small metal plate inside the projector unit that is slid to one side by a small solonoid when the main beam is activated. prob just that stickin .ud need to pull the lamp out and see if u could free it off.
Old Jan 17, 2010 | 10:19 AM
Sounds like a sticky relay, but fraud should easily spot this.
Tap each relay when it is stuck and the duff one will let go/de energise/turn off.
Old Jan 17, 2010 | 05:58 PM
groomers's Avatar
groomers
they have seperate bulbs for dip/main as tabetha has said sounds like a sticky relay realys are below the glovebox or under the bonnet on the n/s
Old Jan 18, 2010 | 09:26 PM
saph_Al's Avatar
saph_Al
seperate bulbs on a HID unit ,personally never seen that before . does it have a standard halogen bulb for the main beam and the progector unit for dip ?
Old Jan 27, 2010 | 07:04 PM
groomers's Avatar
groomers
yup separate lenses all hid lights have separates bi-zenons do both
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Kam B
Sep 24, 2015 10:40 AM
RSmark84
Sep 13, 2015 01:29 PM
