Clutch
Old Jan 13, 2010 | 06:06 PM
Canbrilla's Avatar
Canbrilla
Question Clutch
Hi, my husband has just got a 2000 1.8 Focus and the biting point on the clutch is high. It gets virtually to the top before the car moves and it's very frustrating. Is it easy to adjust? Any help gratefully accepted.
Old Jan 13, 2010 | 06:12 PM
stickertone's Avatar
stickertone
Default clutch
you cant adjust the biting point.... my girlfriends got a focus with a high biting point, been like that for 18 months...
Old Jan 13, 2010 | 07:12 PM
If it's hydraulic just let a little air in, this will lower the biting point.
Old Jan 13, 2010 | 09:14 PM
phil_focus's Avatar
phil_focus
thats just going to mask a problem...if it works.
try doing a couple of tests.
1. with the handbrake on see if you can fully release the clutch in first gear, engine running.
2 if say doin 50mph in 4th and you boot it do the revs shoot up and speed do bugger all?? (more noticeable on a hill)
even without doing those checks i would say you're clutch is nackered and if it doesnt do any of the above its prob very worn and needs changing!!!
ps, i'm an experianced(ish) focus owner. my mum had a w reg 1.8 petrol for years that i learnt to drive on and drove for first 2 years i was on the road. that needed a new clutch after my bro landed his glider out in a farmers PLOWED field and we had to to the trailer accross the furrows to get to him...that didnt do much good for the underside either tbh.
and i have had my w reg 2l petrol for just over a year now. clutch gott replaced before i got it though at about 74k.
hope this helps
Old Jan 14, 2010 | 12:04 PM
My comment was based upon no mention of slipping, so I assumed it doesn't.
Old Jan 14, 2010 | 03:50 PM
Canbrilla's Avatar
Canbrilla
Thanks everyone. Tabetha, no the clutch isn't slipping. I'll see a mechanic about it anyway and try to get it fixed.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
