Charge Carrier modifcation
Old Jan 6, 2010 | 11:03 PM
djchurch2001's Avatar
djchurch2001
Default Charge Carrier modifcation
On the ERST the charge pipe goes up and over the head and when the car gets hot it heats up causing the air inside to heat up. i have been told that you can mod this so the carrier goes around the side and not over the head. Is this correct and if so what parts do i need or will have to get something made.
Old Jan 6, 2010 | 11:38 PM
fiend's Avatar
fiend
You could fit an XR3i inlet?
Old Jan 8, 2010 | 08:21 PM
Or introduce some underbonnet cooling, via vents etc ?
Old Jan 8, 2010 | 08:57 PM
saph_Al's Avatar
saph_Al
Sounds like a lot of work for not a lot of gain to me bud , the advantages of redirecting your charge pipe to lower ur temp by a degree if that on a very hot engine seems a bit of a waste of time, as sugested try introducing extra cooling an see if it makes a difference
Old Jan 9, 2010 | 06:42 AM
JesseT's Avatar
JesseT
There is more heating done at the inlet manifold than in the charge carrier. Fitting some extra heat insulation between the inlet and the cylinder head would have more gain. It is also dead easy and effective to just heat wrap the carrier if you are worried by this.
Old Jan 9, 2010 | 06:53 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
is the mfi xr3i inlet manifold a direct swap.i know it will fit but it wouldnt have the proper plugs etc on it?
Old Jan 9, 2010 | 08:33 AM
JesseT's Avatar
JesseT
It's not a direct fit, but very easy. The RS1600i inlet is even easier.
155lee
Oct 27, 2015 04:55 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
