ERST wont start when engine is warm
Old Jan 6, 2010 | 09:55 PM
djchurch2001's Avatar
djchurch2001
Default ERST wont start when engine is warm
the car will fire everytime when cold but once it reaches running temp you turn the car come back to it 5 mins later and it wont fire. The car is turning over but wont fire but it will after you keep trying. What is causing this?
Old Jan 6, 2010 | 10:01 PM
pani_k's Avatar
pani_k
PassionFORD Member
Starter motor mate common issue gets too hot.
Old Jan 6, 2010 | 10:02 PM
Chopshop85's Avatar
Chopshop85
Get the down pipe heat wrapped! sorted mine out!
Old Jan 6, 2010 | 10:05 PM
djchurch2001
its not the starter motor as the car is turning over it just wont fire
Old Jan 6, 2010 | 10:33 PM
pani_k's Avatar
pani_k
PassionFORD Member
Still the starter motor mate what happens is the heat from the turbo and down pipe heat it up and due to probably no heatshield on it the heat causes it to fail when starting from hot. Common problem mate.
Old Jan 6, 2010 | 10:52 PM
djchurch2001
thats strange because i thought it was a fuel or air problem as the starter motor is turning over. I have had the overheating problem before where the motor wont even turn but in this case it is. What is the best way to fix this problem?
Old Jan 6, 2010 | 10:55 PM
pani_k's Avatar
pani_k
PassionFORD Member
Should be a heat shield over it mate as said or you can knock something up and as suggested wrap up your turbo downpipe.
Old Jan 6, 2010 | 11:00 PM
djchurch2001
no there is not where can i buy the heat wrap as i have looked on line and cant find any
Old Jan 8, 2010 | 08:25 PM
Heat wrap = ebay.
Fitting it won't cure the problem however, as you point out the engine is rotating fast enough to catch and not really slugishly, more likely to be a sensor problem or some toher lecky fault.
Next time it doesn't want to start check for a spark, crack a injector pipe and see if there is fuel flow.
JoeyBoyden
20
Aug 22, 2015 03:23 PM
NoLeafClover
Aug 19, 2015 09:50 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
