fiat coupe brembo brake calipers on frst questions?????????
anyboby fitted or have any advice regarding fitting these calipers to frst or any rs?
i have been told that they are the same as focus rs!!!!!!!!
need to look into getting uprated brakes,stick with esc cos set up or go different route?
if any has seen these calipers they look the bollocks
will fit all depending on wheels you want to use. also really need to use custome bells and maximum 315mm rotors for a normal 17" wheel maybe get away with 330mm rotors on a MO type wheel.
Currently working on fitting some RS focus ones to a FRST at the moment, will be abel to help more in the next couple of weeks.
NC53
13-09-2015 03:05 PM
