t25 escort cos management upgrade help
i want 350 bhp from my small turbo escort cosworth, i no mechanically what to do, like turbo intercooler exhaust etc. but im stuck on management. i no the eec4 will not be compatable for 350. is their a plug and play kit to use level 8 ecu with twin coils? as i dont really want to fit a complete engine loom from a sierra.
any helps apprieciated
thanks
thanks
thanks
thanks
Put a programable ecu on instead and a custom loom its a nice and easy fit.
Mark
thanks
have you got link 2 the thread. because i thaught you could only reprogramme eec4 to around 290bhp max (which mine is already)
is there any way to put level 8 on standerd eec 4 loom? (obviously the cranksensor triggers different)
cheers guys, i just want to use a t34 with around 350 bhp ish. and around 1.5-1.7 bar boost
This is the thread https://passionford.com/forum/ford-e...bo-cossie.html
The 290 (ish) bhp limit is for the standard injectors, not the ecu.
See this post for what can be altered in a ST eec-iv https://passionford.com/forum/ford-e...ec-iv-ecu.html
