either or ?
Old Dec 28, 2009 | 01:57 PM
roccomania42's Avatar
roccomania42
Default either or ?
hi folks im a newbie here and youve guessed it i have a problem, ive had my mk5a cabby since last summer but have hardly used it due to lack of time and problem with it.When driving it goes ok for a bit then when you either give it too much gas or not enough it chugs like its running out of petrol, ive seen two mechanics one said throtle response sensor and the other said no because when its idling and you rev it up it doesnt chug then, he says its the map sensor, any help would be appreciated.
Old Dec 28, 2009 | 02:15 PM
cozzy jeff's Avatar
cozzy jeff
have you tried the simple things first like plugs and leads,could be one of these items breaking down under load,
Old Dec 28, 2009 | 02:54 PM
Alvyn's Avatar
Alvyn
try a new fuel filter also!
Old Dec 28, 2009 | 11:34 PM
roccomania42
i have tried new plugs and it went great for a quick run ,i then parked it up thinking ok great,came back later took it out and chug was back.
Old Dec 29, 2009 | 07:52 AM
Alvyn's Avatar
Alvyn
just had a re-read ur 1st post could also be the coil pack breaking down!
