Car Temperature
Old Dec 23, 2009 | 06:46 PM
Bruckner's Avatar
Bruckner
Default Car Temperature
Today I purchased a W reg Ford Fiesta 5 door 1.3 and was wondering what the maximum engine temperature should be. On previous cars owned by me it was just a case of keeping your eye on the temperture gauge, but it would appear that on this car the temperature is given in numbers (degrees Celsius) and so was wondering what is the normal temperature for this car.Thanks for any help.
Old Dec 23, 2009 | 07:13 PM
Not sure on yours, but around 85C average, but engine dependant up to 105C when hot as fans come on.
So long as the cooling fan works and it doesn't overheat or have a crap heater, be slow to warm up it should be ok, what temps are you seeing, there can be quite a variation between different types of engine, some even beleive a cooler running stat will safeguard a head gasket from overheating damage!!
Old Dec 23, 2009 | 07:36 PM
Bruckner's Avatar
Bruckner
Thank you, Tabetha, for your reply. It was very kind of you. The figure you give seems to be around the temperature I have experienced. Mind you, I`ve only driven a few miles in it. The reason I ask is that when I was driving home from shopping I noticed a rather loud noise, which at first I thought it might be the noise from the road via the tyres. It would appear though that it was the fan operating. Now, at this time of the year when it`s freezing I`ve never experienced the fan coming into operation as the freezing cold air hitting the radiator was enough to cool the engine. I`ll keep my eye on the situation and look out for a drivers manual which was not supplied with car. Thanks again, Bob
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
