Very weird idling stalling.
Old Dec 23, 2009 | 05:25 PM
Dahl88's Avatar
Dahl88
Default Very weird idling stalling.
At cold my car runs with 1100 rpm, and at operating temperature it runs 1700 +
I have NO IRV mounted p.t, due to me ordering a new one home, the old irv didnt work either.
So now i dont know what to do, redo the settings at the butterfly throttle body?
Some tells me it due to "false" air being sucked in by a crack in a hose somewhere but when i take my hand and block the inlet, the car dies, so it shouldnt be this?
Got ANY suggestions what to do?
Old Dec 23, 2009 | 06:03 PM
oldford's Avatar
oldford
Normal behavior without any device regulating idle rpm's.
When the engine is cold the fuel doesn't mix proper with the air, and only a part of the mixture burns. When the engine is hot the fuel mixes properly and everything is burned.
Old Dec 23, 2009 | 06:45 PM
Dahl88's Avatar
Dahl88
Its is? I mean how to i bring the idle down? The irv cant bring it down, unless its open ofc.
Old Dec 23, 2009 | 06:58 PM
oldford's Avatar
oldford
If you bring down the idle rpm without a Idle valve it will stall when cold.
I would use a new Idle valve.
Old Dec 23, 2009 | 07:34 PM
Dahl88's Avatar
Dahl88
Yeah but how can it brind my rpm down when cold/hot by mounting the irv again mate?
Old Dec 24, 2009 | 09:43 AM
Dahl88's Avatar
Dahl88
Cuz letting more air in p.t (as the irv does) wont get the idle to fall to normal.
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
