A.R.P. STUD AND NUT KIT TORQUE SETTINGS
Old Mar 9, 2004 | 09:56 PM
Default A.R.P. STUD AND NUT KIT TORQUE SETTINGS
I have a sierra cossy and need to know the torque settings when using the A.R.P. stud and nut kit. Can anyone help me? [/b]
Old Mar 10, 2004 | 07:30 AM
Guinnless's Avatar
Guinnless
Depends how soon you want a cracked block
Don't use 'em mate. Either long stud (if a 200 block) or standard head bolts.
Old Mar 10, 2004 | 03:38 PM
doh!
good advice though mate! there not worth it as instead of the bolts being aloud to stretch its guna wana give somewhere and thats guna be your block!
Old Mar 10, 2004 | 03:39 PM
PJay's Avatar
PJay
Std headbolts all the way
Old Mar 10, 2004 | 09:57 PM
velocity's Avatar
velocity
whats the difference between a long stud and a standard head bolt do you still use a nut w ith the long stud type or is it just a longer/modified bolt
Old Mar 11, 2004 | 07:38 AM
Guinnless's Avatar
Guinnless
You use a nut with the long studs. Also beware there are some cheap long studs out there...
Old Mar 15, 2004 | 12:26 PM
The threads inside the block taper slightly towards the bottom. When fitting a stud and nut kit, the block thread should be taped out straight, then the stud fitted and torqued. Then when fitting the head, torque the nut down to specification. Doesn't come cheap.
That’s what’s been done on my Escort Cossie.
John
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
