need a wire that is switchable and live during cranking
Old Dec 21, 2009 | 07:27 PM
john_d's Avatar
john_d
Default need a wire that is switchable and live during cranking
as in the title, i need a wire that is swichable live but stays live during cranking.
ive ruled out:
radio, not live during cranking
fag lighter, perm. live
ignition acc, not live during cranking
anyone offer anything else?
Old Dec 21, 2009 | 07:31 PM
JesseT's Avatar
JesseT
For what and on what car? Coil pack +12V live is one choice.
Old Dec 21, 2009 | 07:33 PM
john_d's Avatar
john_d
cant use the coil pack as thats what i need it for.
its my project fiesta, im using a zetec loom and a 2l engine
Old Dec 21, 2009 | 08:26 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
which mk fiesta?
if it was a carbed one, use the anti-dieselling solenoid wire
or go directly to the ignition barrel.
Old Dec 21, 2009 | 08:35 PM
john_d's Avatar
john_d
there is no switchable wire thats live during cranking on the barrel as far as i know, atleast not that ive found.
im using my original interior loom but the engine loom is a fiesta si, not sure where the anti-diesel soleniod is
Old Dec 21, 2009 | 09:20 PM
jon@work's Avatar
jon@work
engine ECU feed wire ?
Old Dec 21, 2009 | 10:32 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
alright, well the original loom should have one or just go through the fuse box and some of the relays will stay live when cranking, coils don't draw much and you would ideally feed off the fuse box to a relay anyhow to run the lot anyways.
so multimeter to the ready or testing light.
Old Dec 22, 2009 | 04:16 AM
JesseT's Avatar
JesseT
Mind you, you can't just take the first wire that has 12V on it and plug a coil to it if things are done properly.
If you have the Zetec loom, then you will have the coil pack connector? Other things also need similarly 12V like injectors and idle valve. Are these also a problem similarly?
Old Dec 22, 2009 | 06:17 AM
john_d's Avatar
john_d
im sure thats permanant?
got both a meter and light, will test next time i work on it
Old Dec 22, 2009 | 08:59 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
ecu feed wire is on a switched ignition feed fella, you could use that and feed a relay of it, you'll be fine then.
Old Dec 22, 2009 | 07:05 PM
john_d's Avatar
john_d
pin 1 on the ecu?
my pins outs has that as POWER +12V fused, does that not mean its permant? that way when u start the engine the ecu doesnt have to re-learn?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
