Escort mk1 rear axle !
Old Dec 18, 2009 | 06:48 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Default Escort mk1 rear axle !
Ive got a rather annoying vibration coming through the transmission somewhere and it keeps wrecking gearboxes ! Ive got 2ltr pint in which a type nine box but the angles of the rear diff and the tailhousing of the box are out ! Could this be my problem ? If so does anybody know what i can do ???
Old Jan 7, 2010 | 06:45 PM
Aidan S's Avatar
Aidan S
It's been a hell of a long time since I worked on a MK 1 escort, so my memory might not be that good, but, does it have a 1 or 2 piece propshaft. If it's a 2 piece (fitted with center bearing) then it's probably the same problem the MK 1 and 2 Granada's suffered from.If it's a 2 piece prop, what you can do is fit some shims or washers, (about 1mm thickness) between the bearing mounting plate and the floorpan. Start off with 2mm worth of shims/washers, and drive the car, if it gets better, keep adding shims until the vibration goes. If it gets worse, remove all the shims and then do the same to the gearbox mounting plate and see how it goes. What this does is basically alters the driveline angle. If it's a 1 piece prop, them just try at the gearbox mounting plate. Another thing to consider is to check the balance of the propshaft and check the UJ's on the propshaft as well.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
