Check rev's should be
Old Dec 18, 2009 | 03:51 PM
fordtwin's Avatar
fordtwin
Default Check rev's should be
Hi, Hubbie has a Ford Focus TDI sport 1.8. When I drive it, to me it feels as though revs are low (just under 1) so when sitting in queues botherin me. My Ford Focus Zetec 1.8 is at approx 1.5. Are these right for the cars, both on late 53 plates. Many thanks
Old Dec 18, 2009 | 04:07 PM
phil_focus's Avatar
phil_focus
i take it your talking about the idle speed??
the diesels have very low cold idle in my opinion but both petrol and diesel should idle at arount 800 - 900 rpm when warm.
to me it sounds like your petrol focus will fail its next mot and not be very nice to drive. it probably just needs a new idle speed control valve but could also be vss or tps depending on symptoms.
Old Dec 19, 2009 | 09:56 AM
fordtwin's Avatar
fordtwin
Default Rev update
Thanks for info. Hubbies car is right then. Mine is a diesel too (prob didnt give correct spec - apol) so will mention it at next MOT as only just had one. Thanks again.
Old Dec 19, 2009 | 10:07 PM
phil_focus's Avatar
phil_focus
hmm that doesnt sound good to me. see if you can get someone to read the fault codes as your gona be using way more fuel than you should.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
