sapphire brakes
Old Dec 17, 2009 | 09:58 PM
rc535's Avatar
rc535
Default sapphire brakes
Hello there i have a 1800 sappphire that im currently using as daily driver but thinking of zetec-ing it or something along the lines, but the brakes dont feel too good at stopping as it is.
I have a xr4, just a 2wd 2.8 that im breaking up and was wondering if i could put the brakes off of that onto mine, if they are even bigger? And also what would i do about the abs as xr4 is not abs?
Ryan
Old Dec 20, 2009 | 10:26 AM
rc535's Avatar
rc535
anyone?
Old Dec 20, 2009 | 10:37 AM
m4tt274's Avatar
m4tt274
u can put the brakes on any norml sierra.
normal sierra models are a 240mm disc
xr4x4 + RSTurbo brakes are 260mm disc single pot caliper
granada/escort/sierra 4x4 cosworth 280mm disc single pot caliper
and 2wd sierra has a 283mm 4 pot but you cant fot these to a 4x4
Old Dec 20, 2009 | 12:44 PM
Yes the xr4 hubs can be swapped direct for the present ones, along of course with the calipers and discs, won't be a awsome improvement though.
Putting on 2wd cossie discs and calipers is easy, as they fit straight onto 2wd hubs after you have tapped out the hole that holds the normal sliding caliper, as the cossie ones are bolted to this lug, think it's either 12 or 14mm, then bolts to suit, the hole conveniently is already the correct size.
This is what I did to my 2.0GL auto, first with xr4i discs then 2wd cossie stuff.
In this answer I am assuming you mean xr4i and not xr4x4, as as has been said xr4x4 stuff is different.
The abs ring is normally present even on cars not fitted as it is part of the spindle/hub, was on the ones I did anyway, but if swapping over stuff mix and match can always be done.
The most effective £ for £ improvement will be to use grooved discs and ebc redstuff ceramic pads.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
